le Mans Classic 2023
Race 3 analysis.
13_BestSectors_RACE 3.PDF
(366.7 KiB) Downloaded 16 times
This shows the relative best sectors. Sector one we came 36th with 58.479, Sector 2 44th with 2:25.509, and sector 3 35th with 2:52.251. The sectors are one from start to Tetre Rouge, 2 from there to end of Mulsanne, 3 from there to finish.
12_LapChart_RACE 3.PDF
(361.34 KiB) Downloaded 15 times
The lap chart shows the relative positions of each car on each lap. In Race 3 we started 32nd, dropped to 33rd, then 40th, back up to 38, then 31st, then 38th, finishing 39th. The rise in position was due to the late driver change. The start position was due to a good fastest lap in race 2.
26_Weather_RACE 3.PDF
(389.08 KiB) Downloaded 17 times
Trying to estimate effect of humidity and temperature on performance is an art. The engine should be better in cool, humid conditions until you start to get icing on the carbs. The tyres should be better with hot track temperature but all then depends on tyre pressure which we played with during practice settling on, I think, 38 psi. hot as we checked pressure at each pit stop and at end of race or practice.
23_Analysis_RACE 3.PDF
(431.08 KiB) Downloaded 19 times
This is informative showing the build up of speed during the race. Chris's best lap coming at the end of the stint, possibly because the late pit stop gave him space and was not held up by similar perfomance cars. The driver change on Lap 5 added about 1min 30 secs to the Sector 1 time.
19_AnalysisByLap_RACE 3.PDF
(385.58 KiB) Downloaded 19 times
This is the most informative chart showing how the late driver change put us on third in Lap 5, but of course dropping down again when we made the change to 9th past the post on lap 6 as faster cars caught up, and way down on lap 7 after the change.
17_FastestLapSequence_RACE 3.PDF
(357.77 KiB) Downloaded 13 times
This shows nothing!
14_BestTopSpeed_RACE 3.PDF
(366.82 KiB) Downloaded 24 times
43 Jowett Jupiter 1951 TSRC3A H. NAERGER
Best top speed 188.1 on lap 2
second best 185.8 on lap 1
third 183.9 on 4
fourth 182.1 on 3
fifth 175.4 on 5
average for race 183,1
01_Grid_RACE 3.PDF
(382.78 KiB) Downloaded 19 times
03_Classification_RACE 3.PDF
(389.45 KiB) Downloaded 18 times
04_Classification_Index_Performance_RACE 3.PDF
(379.56 KiB) Downloaded 18 times
Last edited by Keith Clements on Fri Jul 07, 2023 12:02 pm, edited 1 time in total.
Night Practice analysis
03_Classification_FREE PRACTICE - NIGHT PRACTICE.PDF
(389.25 KiB) Downloaded 16 times
26_Weather_FREE PRACTICE - NIGHT PRACTICE.PDF
(388.75 KiB) Downloaded 21 times
It was wet and cold. Perhaps next time we will alter tyre pressures accordingly. We will probably not alter carb settings to better performance but to get that little extra it might help.
23_Analysis_FREE PRACTICE - NIGHT PRACTICE.PDF
(409.54 KiB) Downloaded 25 times
The long gap here was due to fixing the top hose that had come off when Chris was driving. Scott followed on and managed to do a 570 deg spin at Indianapolis when blinded by headlights in the mirror. Mirror was blanked off for night race.
14_BestTopSpeed_FREE PRACTICE - NIGHT PRACTICE.PDF
(366.18 KiB) Downloaded 11 times
13_BestSectors_FREE PRACTICE - NIGHT PRACTICE.PDF
(366.28 KiB) Downloaded 13 times
This shows your ideal lap compared to the best lap managed by the drivers.
43 43 Jowett Jupiter 1951 TSRC3A Ideal = 7:52.547 Best = 8:23.492 (54)
Day Practice.
03_Classification_QUALIFYING - DAY PRACTICE.PDF
(389.64 KiB) Downloaded 16 times
26_Weather_QUALIFYING - DAY PRACTICE.PDF
(389.69 KiB) Downloaded 11 times
23_Analysis_QUALIFYING - DAY PRACTICE.PDF
(437.07 KiB) Downloaded 12 times
17_FastestLapSequence_QUALIFYING - DAY PRACTICE.PDF
(358.06 KiB) Downloaded 19 times
14_BestTopSpeed_QUALIFYING - DAY PRACTICE.PDF
(367.36 KiB) Downloaded 18 times
13_BestSectors_QUALIFYING - DAY PRACTICE.PDF
(367.48 KiB) Downloaded 13 times
Sector 1 54th 1:02.111
sector 2 48th 2:32.651
sector 3 45th 3:01.497
Comparisons with other cars, particularly those in the same class may show up something useful. Drivers reported ease of passing on corners but lack of top speed on staights. Some aero dynamic changes are required as well as more power at the top end and higher max revs.
Race 1 analysis
04_Classification_Index_Performance_RACE 1.PDF
(379.62 KiB) Downloaded 11 times
03_Classification_RACE 1.PDF
(389.66 KiB) Downloaded 14 times
26_Weather_RACE 1.PDF
(388.9 KiB) Downloaded 11 times
23_Analysis_RACE 1.PDF
(433.7 KiB) Downloaded 15 times
19_AnalysisByLap_RACE 1.PDF
(385.39 KiB) Downloaded 14 times
17_FastestLapSequence_RACE 1.PDF
(358.73 KiB) Downloaded 14 times
14_BestTopSpeed_RACE 1.PDF
(367.26 KiB) Downloaded 15 times
13_BestSectors_RACE 1.PDF
(367.49 KiB) Downloaded 18 times
12_LapChart_RACE 1.PDF
(361.47 KiB) Downloaded 12 times
01_Grid_RACE 1.PDF
(382.96 KiB) Downloaded 13 times
Last edited by Keith Clements on Fri Jul 07, 2023 12:03 pm, edited 1 time in total.
Race 2 results (no analysis!)
04_Classification_Index_Performance_RACE 2.PDF
(379.63 KiB) Downloaded 16 times
03_Classification_RACE 2.PDF
(389.43 KiB) Downloaded 14 times
01_Grid_RACE 2.PDF
(382.76 KiB) Downloaded 17 times
The track in 1950
Compare this to the current track whose image is in a previous post.
Re: le Mans Classic 2023
Trevor Spero wrote: 'Excellent result especially from a team of aged Jowetters'
Dear Mr Spero, Go wash your mouth out with strong carbolic soap immediately :lol: :lol: - I was very much part of this years Le Mans team and would care kindly not to be dumped into the 'Aged Jowetters' bracket just yet !
Image credit: Charlie Killick
Playing with the big boys and winning at it - Chris Bates pilots the Jupiter past the 1952 J2X Allard (all 8 cylinders 5,394 cubic inch of it) to his next target the 1950 Talbot Lago T26 GS (Inline 6 cylinder 4,482 cubic inch) which Chris passes within the next mile :D
