Jupiter Wiring Loom
Jupiter Wiring Loom
I remember reading in the great SC rebuild that there were two suppliers of Jupiter wiring looms, one good the other not so good. Can anyone point me in the direction of the good supplier.
John Dolphin
E3SA 887
E3SA 887
Re: Jupiter Wiring Loom
I think Keith ended up placing the order (following advice from other members) so should be along to advise shortly. It might be in the thread, and I can confirm you are quite right. There are two options - one was deemed inappropriate due to the gauge of wire used by one supplier for the amps it needed to carry.
I think there was also the choice of plastic or braided wire covering from the supplier we used. From memory it could have been these guys, but check with Keith before placing an order http://www.thewiringharness.co.uk/
I bought the loom for the SC through JOAC There were modifications required such as splitting and adding to the rear harness to accomodate the SC boot electrics. The loom came with indicators as well as trafficator wires and also front fog/spot lamp wires. You may like to add rear fog lamp and reversing light wires though.
Thanks for the replies Jack & Keith. I'll give JOAC spares a ring.
John Dolphin
E3SA 887
E3SA 887
Users browsing this forum: No registered users and 13 guests
