Jupiter midship bearing
Would someone please provide the manufacturer's number or the bearing spec? A quick search here turned up that the NZ club uses a Toyota wheel bearing, but no details. Thanks.
Re: Jupiter midship bearing et al
Midship
88506 ( or 6206FF ) Deep Groove Wheel Bearing 30x62x16x24 £15.01
or
KG Brand 88506 Automotive Bearing 30x62x16mm £8.96
Front wheel
LJ12RS Imperial Rubber Sealed Deep Groove Ball Bearing 1x2-1/4x5/8 inchs £7.10
MJ3/42RS Imperial Rubber Sealed Deep Groove Ball Bearing 3/4x2x11/16 inch £6.70
Seals
Timing cover 1.87x2.75x0.37 inch Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R21 / SC £2.94 (July 2023 £3.06 +vat)
better is a double lip and .5 inch wide
Front hub 1.62x2.37x0.37 Inch Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC Double LIp £6.37 (July 2023 £6.63 +vat)
a metal cased version is available at £6.81 +vat but since I use sealed for life bearings not really required.
A half inch wide version can also be fitted at £5.68 +vat
Crankshaft 3x4x0.5 Inch Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC £4.06 better double lip £4.22 +vat
1.31x2.25x0.37 inch Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R21 / SC £5.46
Gearbox 1.12x1.75x0.25 Inch Nitrile Rubber Rotary Shaft Oil Seal with Garter Spring R23 / TC £6.04
Javelin Steering box 3.00x2.25x.037 inch Double Lip £6.28 +vat
From
simplybearings.co.uk
Re: Jupiter dynamo bearing.
6203-2RS/C3-CDX Codex 62032RSC3 Rubber Sealed Deep Groove Ball Bearing 17x40x12mm
I restocked my spares of bearings and seals this week when getting this bearing for the one that failed on the trip to Le Mans.
