Oil viscosity
Oil viscosity
This chart shows the relationship between SAE and ISO (International Standards Organization) classifications , plus the AGMA (American Gear Manufacturer's Association) grades for gear oils.
Example: SAE 140 gear oil is required for a differential unit. Cross to ISO 460.  If a SAE 90 is required, use ISO 220 oil.  If a 90W-140 is called for,  ISO 320 might be correct for the application. Note how SAE Crankcase oil classifications are in a different band than the SAE gear oils. An SAE 10W-30 would be an ISO 32-100.  W in SAE nomenclature stands for 'Winter'.
Users browsing this forum: No registered users and 7 guests
