Linking JowettGallery Image to JowettTalk
Steps to link JowettGallery image to JowettTalk
Linking JowettGallery Image to JowettTalk post. Detailed explanations are inIntegrated Get Item links method Old properties method
g_id=34993,_ /help/JTlinking,_ Forumadmin,_
Select image menu
Right click on image (W indows) hold finger on image (Android)
Choose preferably the lower resolution image, unless the detail is important. Right click (or hold finger on) the image to bring up a menu. Select properties (view image). Then select and copy the URL with the downloadingitem command in it. CTRL+C on Windows. Select and hold and Copy on Android.
g_id=31137,_ /help/JTlinking/link1.jpg,_ Forumadmin,_
Copying the downloading item URL
Right click (or hold finger on) the image to bring up a menu. Select properties (\'view image\' Android). Then select and copy the URL with the downloadingitem command in it. CTRL+C on Windows. Select and hold and Copy on Android.
g_id=31149,_ /help/JTlinking/link2_003.jpg,_ Forumadmin,_
Cancel properties window
Cancel properties window and return to JowettTalk window or tab
g_id=31152,_ /help/JTlinking/link3.jpg,_ Forumadmin,_
Pasted IMG link
The link is pasted between the square brackets
The link is pasted between the square brackets with nothing else in between them.
g_id=34998,_ /help/JTlinking/link5.png,_ Forumadmin,_
