Hi, new member here. I’ve been reading a lot of the posts - enlightening!
I own a 1953 Bradford and just going through the process of registration - the last time it was registered was 1968.
My question is: is there a list of oils and greases recommended for the Bradford?
Bruce (Langley)
Bradford Lubrication
- Your interest in the forum: I now have a CB Bradford kit of parts - one special coming up!
- Given Name: Jeremy
Re: Bradford Lubrication
You could do with getting an instruction book - they come up on ebay
I presume your Bradford is a CC rather than a CB like mine but for that the book lists:
Engine - 4.5 pints - Castrol XL summer/Essolube 30 and Castrolite/Essolube 20 winter
Gearbox - 1.5 pints Castrol XXL/Essolube 40
Rear axle - 1 pint Castrol XT/Essoluve gear oil (SAE140)
Grease - Castrolease Heavy
Shock absorbers - Armstrong Super Thin Fluid
Hope that helps!
Hope that helps!
If you are a club member then you should have access to the JowettTalk Library where the manuals and loads of other useful articles are stored.
Bruce, I have sent you a PM (private message)
Bruce I have added you to Club Members and NZ groups so that you can see the Library. I was confused by the sign off of Langley rather than Loader.
