1953 Bradford Truck barn find
The Bradford man
Your interest in the forum: Jowetts, Subarus, Any thing with a Boxer engine.
Given Name: James
Post by The Bradford man »
Just picked up a 1953 CC Bradford Truck barn find. It’s been parked in the shed for at least 30 years.
Not run in that time.
James~
1953 Jowett Bradford CC truck restoration project
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
Possibly the only person or one of the few that owned one of every type Bradford at the same time CA,CB,CC,CD.
1935 Jowett 7 Project unfinished.
Re: 1953 Bradford Truck barn find
On the road for April?
The Bradford man
Given Name: James
I wish lol. I just want a holiday then go work on it lol
James~
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
Hello James.
Looks quite a reasonable task when compared with the photo of a 1934 long saloon a friend of mine had at one time.
Best of luck with it.
That all-metal body looks interesting? I thought they were usually wooden load spaces.
Is this an option, a 'special' or a very nicely made DIY job?
I wonder why it came off the road? (Nasty bump on the N/S from wing) If it was simply disused then it should not present too much of an effort to get it running at least.
After that . . ...
My 1st Bradford had a tray just the same.
Ah Ha!
I wonder I this was an 'export' feature?
Any more in the UK?
Could the chassis number shed any light, I think there may have been an extra digit in the number?
These things are sent to make our life 'interesting'!
Alastair Gregg
Your interest in the forum: E2 SA 922 HKY 770
D7 CB 6079 CVG 166
E2 PD 22113 MVU 377
Given Name: Alastair
Post by Alastair Gregg »
Ian,
Doug Rath in Oz has one, I, like you, suspect it was an export version.
I will ask him if he has any info.
Compliments of the Season,
Alastair Gregg
The Bradford man
Given Name: James
It’s a NZ new one. Think the deck maybe made in Ashburton. Saying that is only a guess. Engine code has it as a knock down on it. It’s registered as a 53 but according to the engine code it’s a 1951. Same engine code on paper work for owners papers.
It was used on the farm a lot. It’s believed gearbox blown 2nd gear
ian Howell wrote: Sat Jan 11, 2020 1:48 pm That all-metal body looks interesting? I thought they were usually wooden load spaces.
After that . . ...
James~
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
The Bradford man
Given Name: James
KDE1CC253
ian Howell wrote: Thu Jan 16, 2020 6:36 pm Ah Ha!
Any more in the UK?
James~
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
The Bradford man
Given Name: James
What do you mean by wooden load spaces?
Thank you
James~
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
dougie
Your interest in the forum: Long time Jowett owner with a Javelin, Jupiter and Bradford.
Given Name: Doug
Post by dougie »
Hello All,
Our CC Bradford utility/lorry what ever you want to call these things has a steel body with timber floor and timber reinforcing on the inside of the sides.
I believe that the vehicles were imported into Australia in cab chassis form and the rear body built by ,and I stand to be corrected, the dealer Liberty Motors in Melbourne.
Our Bradford is totally original as regards the body work.
Some photos are here.
https://www.facebook.com/groups/jowett.australia/
Cranky Wife,No Cupholders.
Jupiter,Javelin, Bradford.
Audi quattro 1985 ,MK 2 Cortina,Fairthorpe Electron Minor 1300
I NEVER MET A HORSEPOWER I DIDN'T LIKE!
I thought this might turn out to be interesting!
By wooden load space I was thinking of not just the floor, but the sides and tailgate as was often the case for 'builder's' type lorries in the UK.
My Bradford van (in the 1960's) had wooden T & G planks for a floor (rotten when I got it) which I/we replaced with a sheet of waterproof ply donated by an adjacent building site.
A wooden floor makes sense, less likely to bend under dropped loads, cheaper, lighter?, and easier than sheet steel when dealing with CKD units.
I'm not so sure about termites though?
