Grease in my rear wheel brake shoes ???
rickjowett
Your interest in the forum: My great great grandfathers cousins were William and Benjamin Jowett, the founders of Jowett Cars Ltd!
1952 Jowett Jupiter E2SAL813
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
2015 BMW X4
Given Name: Rick
Post by rickjowett »
I need to fix this obviously. I removed my rear wheel brake drum to check my shoes, and I found grease in there. Dangerous for sure. What is broken and is there a DIY on how to fix it? A seal of some type for sure, any ideas on what it is and where I can get one? :?
Re: Grease in my rear wheel brake shoes ???
Is it grease or oil?
Grease comes from the wheel bearing and oil from the differential.
Look at this index.. viewtopic.php?f=65&t=4564#p24814
Choose Rear hub
Two seals are employed. 29 and 25
Maybe you get these from JCS or if not a good seal supplier although I know there are some issues with supply of the inner one.
Look at viewtopic.php?f=152&t=1207#p42347
Outer:
SKF CR18658 Double Lip Nitrile Rotary Shaft Seal 1.875x2.75x0.313 inch
Inner: Payen NA325 equivalent:
SKF CR13157 Double Lip Nitrile Rotary Shaft Seal 1.313x2.282x0.25 inch Part No: CR.13157 Brand: SKF Price each: £9.87
Worth checking taper for wear. Make sure nut can be tightened correctly and washer does not touch shaft.
Also make sure the grease bleed hole is open and do not over pack grease.
rickjowett
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
2015 BMW X4
Given Name: Rick
Thanks for your reply.
The first link says "I am not authorized to view this site" ???
rickjowett
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
2015 BMW X4
Given Name: Rick
It is grease, not oil
This site is full of helpful people and is a great resource for Jowett owners. It's great to see you asking questions. I'm in California. Drop me a PM and I will send a phone number and can walk you through some of the Jowett quirks.
Hi Rick.
You need to be a member of a Jowett club to view parts of the website. Are you a member?
rickjowett
1993 Ford F150 XLT
2005 Corvette
2006 BMW 750Li
2015 BMW X4
Given Name: Rick
Not currently. I used to be a member of the JOAC and Jowett Car club, but paying as a US citizen to the UK was such a hassle I gave up on both after a few years. This was back in the late 90's / early 2000's. Is the payment method easier now?
Now pay with PayPal! see email I sent you.
