Dynamator wiring
Dynamator wiring
I had a question from Mogens in Denmark.
I`m sending you this email, because I am trying to mount the stealth dynamator I bought at the Birmingham
car show 2019, when i met you. I hope you can help me with the wires for my Jupiter, the control Box regulator
is a Lucas RF 95 (Photo), can you maybe help me with some diagram of the wires.
Hi Mogens,
You do not use the control box at all.
Dynamator Positive Earth Instructions.pdf (accuspark.co.uk)
which is positive earth (NOTE you need to add a relay to the warning light) or, if you have changed to negative earth, much simpler.
Dynamator Negative Earth Instructions.pdf (accuspark.co.uk)
Note I have added a 50 A fuse to my circuit as well as cut out switches on both main feeds from battery.
file.php (4501×6001) (jowett.net)
Josephine rebuild - Page 7 - JowettTalk
This is also a good diagram using the box terminals
http://www.ttalk.info/DynamatorWiring.html
