Front hub lock ring
- Your interest in the forum: Interested in reading and contributing to the technical section, and to Javelin matters in general. Car restorer and carpenter.
- Given Name: Paul
Front hub lock ring
Basic question: is the right hand (in UK offside) front hub locking ring (with the holes for a pin wrench) left hand threaded? Many thanks. Having difficulty removing this on a Jupiter.
Re: Front hub lock ring
NO. It is locked using a screw with a pin at its end. Often this has broken off or mangled the thread. The tool with 6 pins that takes it off is often inadequate to shift it and a pin punch is required which invariably damages the ring. New rings are available.
- Given Name: Paul
Thanks
