Distributor springs
Distributor springs
My daughters car was running hot at idle & a bit rough.
A bit of testing showed the advance was coming on to early.
The culprit was worn springs, the remedy was finding the least worn ones. Car now starts and idles perfect.
Does anyone know the correct springs for our cars?
And a source?
alexander
Your interest in the forum: Javelin 1953 That has been off the road for a number of years needing some TLC. Also have a 1959 TR3a and a Francis Barnett 1951Merlin.
Given Name: Dave
Re: Distributor springs
Post by alexander »
Try distributor doctor on 01984 629540
There is a lot of discussion on JT about this. It is probably not the springs but wear everywhere. If you do contact Distributor Doctor in the UK I would suggest getting the unit totally rebuilt by him to the Clements advance curve.
Email him and see if he can send to you.
My main concern is my Bradford springs.
My Jupiter runs electronic ignition.
