Aluminium cylinder heads for a twin
I've just unearthed (from the depths of a garage) a couple of aluminium cylinder heads which obviously fit a Jowett flat twin engine - (why should they not do!!). They have 'R' and 'L' cast into the outer surface. As you can see from the photo, the spark plug comes out at right angles to the head. They take a CA/CB type head gasket. The plugs are 14mm type.
Are these from a WP stationary engine, and what about the compression ratio?
Measure the combustion chamber volume using a pipette. Remember chemistry?
Much too complicated.
Wi't rack o' th' eye and twist of t' gob, someone will know the answer.
PAUL BEAUMONT
Your interest in the forum: Bradford Registrar and club Chairman
Given Name: Paul
Post by PAUL BEAUMONT »
I am almost certain that the 1940 van that belongs to our friend in Sheffield - sorry Tony its too late for the grey cells to recall his name - is fitted with just such heads.
Paul Beaumont
george garside
Post by george garside »
[quote="PAUL BEAUMONT"]I am almost certain that the 1940 van that belongs to our friend in Sheffield - sorry Tony its too late for the grey cells to recall his name - is fitted with just such heads.[/quote]
they were standard on the 1940 model year cars but I think the vans retained normal cast iron heads but not absolutely certain. The late 39 eight tested by autocar in july '39 also had them but not the other 1940 features of vacuum advance, borg & beck clutch & enclosed flywheel. I have never been able to ascertain whether they were fitted to all 1939 model year cars ,whether this was a mid season change or whether Jowett's just stuck them on the autocar road test car.
I tried a pair on a CB Bradford with absolutely no noticeable difference in performance!
PAUL BEAUMONT
Given Name: Paul
Hi both George and Tony!
Firstly, as it is not just past midnight the grey cells remind me that I spoke of John Ellis and what he calls the Idle van. It definitely had such heads last time I saw it, but I am not sure if the engine is original to the car. I also recall him telling me that it had a number of "new" features on it.
Paul Beaumont
I cannot imagine a company selling cylinder heads operating from Regent Street today!
k. rogers
Your interest in the forum: 1933 7hp Kingfisher
1952 Bradford special
Given Name: Ken
Post by k. rogers »
Thought some of you may be interested in the attached article from a 1932 Light Car & Cyclecar.Image
george garside
[quote="k. rogers"]Thought some of you may be interested in the attached article from a 1932 Light Car & Cyclecar.[/quote]
any chance of this article being scanned into oneof the galleries so that the print is legible.
I haave not encountered these accesory heads which are quite different from the official isssue 1940 veriety in having plug at top centre and smaller water jacket capacity.
k. rogers
Given Name: Ken
Post by k. rogers »
Sorry George, I didn't realise it would be so illegible, so I've uploaded the same on my Gallery section which I believe you can then save on your computer and zoom in (correct me if I am wrong, Keith!). I wonder if any of these heads still exist?
The Bradford man
Your interest in the forum: Jowetts, Subarus, Any thing with a Boxer engine.
Given Name: James
Post by The Bradford man »
I read in one of the Jowett books that the Godfey Weasels had alloy heads
James~
1953 Jowett Bradford CC truck restoration project
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
Possibly the only person or one of the few that owned one of every type Bradford at the same time CA,CB,CC,CD.
1935 Jowett 7 Project unfinished.
PAUL BEAUMONT
Given Name: Paul
: http://www.youtube.com/watch?v=rqN_wXJ7 ... re=related
Hoping that this works! Look at them heads!!
Paul Beaumont
The Bradford man
Given Name: James
I was looking at that vid a while ago and didnt even notice they had alloy heads.
Question... How long will the alloy heads last for the jowett 7/8etc?
Do they corrode badly? Some heads ive seen off 1970s etc cars have corroded so badly
James~
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
PAUL BEAUMONT
Given Name: Paul
I do not see any reason why they should corrode more than manifolds do on the twins. I know some pre-war manifolds are now a bit "iffy", but Bradford ones seem to stand up OK and that with a history of little or no antifreeze, I suspect.
Any one else got ideas?
Paul Beaumont
The Bradford man
Given Name: James
dads 1939 8hp manifold got very thin and broke and badly corroded. thats why i was asking about the alluminum heads.
Whats the difference between alloy 8hp/7hp compaired to the normal steel/iron heads? apart from the metal they are made from :lol:
James~
1937 Jowett 10hp
1939 Jowett 8hp
Chris~ RIP
